Home » Sponsored » Pi Speakers » bracing theater pi 7's
Bracing [message #33050 is a reply to message #33044] Fri, 23 March 2001 18:02 Go to previous messageGo to previous message
I recommend placing braces every 18". For the larger bass reflex and cornerhorns, the best way to do this is with 2" x 3/4" hardwood stock fastened perpendicular between panels and connecting them. So in your case, I would connect the front and back baffle panels together with two braces - one placed between the woofer and cabinet bottom and one half way between the woofer and the top. It's easy and effective.
Also use the braces as a place to put R11 or R13 spanning the cross-section of the cabinet. You want insulation to cover three-sides of the cabinet's interior, and in large cabinets you also want to break it up into sections seperated with sheets of insulation spanning the cross-section. It does a great job of trapping unwanted midrange reflections but bass will pass right through.
Previous Topic: Crossovers and phase shifts
Next Topic: *ping* RBP - L-200 project update
Current Time: Thu Nov 05 19:22:05 CST 2026
