Home » Sponsored » Pi Speakers » plywood vs mdf
Re: plywood vs mdf [message #33036 is a reply to message #33035] Thu, 22 March 2001 22:09 Go to previous messageGo to previous message
R. Hertz is currently offline  R. Hertz
I don't think it would be correct to characterize the sound of a loudspeaker based on the enclosure alone. There are other factors at work such as enclosure alignment, damping material, crossover design, and the overall voicing of the loudspeaker. If you used two identical speaker systems, but one in a plywood cabinet and one in an MDF cabinet, then you might be able to draw a valid conclusion. But if you listen to a Vandersteen model 3A with an MDF enclosure and try to compare it with a Klipsch with a plywood enclosure, your conclusion will be invalid.
Previous Topic: Question for Wayne
Next Topic: Hello World!
Current Time: Tue Oct 20 16:55:22 CDT 2026
