Home » Audio » Group Build » Group Build Line Array Project
Re: Routing Out The Front Baffles [message #32092 is a reply to message #32085] Thu, 26 October 2006 21:10 Go to previous messageGo to previous message
If you are using a drill press, with either a hole saw or fly cutter. Mount a temp say 2’x4’ MDF table to your press. Now you can clamp a fence to it, slide your baffle along it and maintain perfect horizontal alignment.
My recessed drivers, are very close together. I scribed a vertical line, then walked off the centers with a pair of divider’s…John
Previous Topic: Smith horns
Next Topic: AudioRoundTable Group Build Room?
Current Time: Sun Nov 22 20:35:45 CST 2026
