Home » Audio » Group Build » Group Build Line Array Project
Re: Routing Out The Front Baffles [message #32086 is a reply to message #32084] Wed, 25 October 2006 14:25 Go to previous messageGo to previous message
For what it's worth, I use a Jasper circle jig on my router to do the cutouts. I make them either 1/2" or 3/8" (depending on the driver) smaller than the oveall diameter of the flange, then I use a rabbet bit to make the recesses.
If anybody decides they're going to build enough speakers to justify buying a router, be sure to get a plunge router - this type is needed to use the circle jig. You don't need an expensive one. Mine is a $99 Ryobi.
Previous Topic: Smith horns
Next Topic: AudioRoundTable Group Build Room?
Current Time: Sun Nov 22 20:35:43 CST 2026
