Home » Audio » Group Build » Ohm Sweet Ohm
Re: Ohm Sweet Ohm [message #31957 is a reply to message #31956] Mon, 11 September 2006 08:34 Go to previous messageGo to previous message
Thats what I needed John; thanks now I can order.
What are you building or listening too John if I may ask?
Now with the completion of the Eico and the tube rec EL 84 I need to start thinking about an amp.
1 I believe that you use less expensive passive parts; matched carbon comp resistors and decent caps; Orange drop 716's etc.
2 A reasonable homebuilt chassis and instead spend the money on tubes and transformers.
What do you think?
Good connectors also.
The one thing I need to study is good grounding and safety practice. I know lot of the safety wiring issues compromise sound but I want it safe.
Bus ground or star ground?
Previous Topic: Heyboer
Next Topic: WOW
Current Time: Wed Nov 04 16:24:03 CST 2026
