Home » Audio » Group Build » SE 300B Project, Part 13 - The finished amp
Re: SE 300B Project, Part 13 - The finished amp [message #31941 is a reply to message #31912] Sun, 13 August 2006 04:04 Go to previous messageGo to previous message
horny is currently offline  horny
hi Damir
Do you made any updates so far
i find the c3g sounds very good
but a little thin in the low mids.
The deep bass is very good with good punch
better than any driver i tryed
but voices have a little less body
i set screen 3 to anode this sounds indeed better than to ground
i have not tryed the led bias
for the rest is the amp pretty good ,clean not harsh go's deep very detailed and also the bass is very detailed
but voices may have more whoomp
do you have any idea what i can try?
Regards Robert
Previous Topic: Any new project ideas for winter?
Next Topic: Spare me some IXP10M45S ?
Current Time: Thu Nov 19 05:38:19 CST 2026
