Home » Audio » Group Build » SE 300B Project, Part 13 - The finished amp
| Re: SE 300B Project, Part 13 - The finished amp [message #31930 is a reply to message #31926] |
Fri, 21 July 2006 04:19   |
horny
Messages: 11 Registered: May 2009
Chancellor |
hi Damir I build the amp and tryed the C3g and ec8010 first i must say i build the amp with ux245 as output tube. I used the C3g driver stage as you post here and the ec8010 at 150v /20m. The ec8010 is very good more hights and more bass then the c3g but the hights are not sparkeling ,not loose. More like an transistor amp. Very impressive but i think not for a long time. The c3g has more fluidness (sorry for the strange talk) i try to explane sound thats not easy  the sound is also more clean and there is a good balance in the whole freq.spectrum So the c3g is staying i like it !!! For me this sounds best but i think that others may like the ec8010 more. Then i tried the ec8010 and the c3g with the same operation points interstage coupled. I have amorphouse interstage tranny's from Tribute audio the opt's are also amorpouse one's from the same builder. The carractre of the tubes is the same now but no there is an naturalnes to the sound its smoother and more relaxed but still dynamic and very very clean. I like the amp most with the c3g driver interstage coupled its also a very simple set up. Robert
By: Damir on Mon, 26 June 2006 12:25
By: Damir on Mon, 03 July 2006 06:08
By: horny on Sun, 09 July 2006 13:26
By: Damir on Mon, 10 July 2006 07:08
By: horny on Tue, 11 July 2006 09:23
By: Damir on Tue, 11 July 2006 10:08
By: horny on Tue, 11 July 2006 10:37
By: Damir on Tue, 11 July 2006 11:33
By: horny on Fri, 21 July 2006 04:19
By: Damir on Fri, 21 July 2006 07:46
By: horny on Fri, 21 July 2006 08:38
Wow! :-)
By: Damir on Fri, 21 July 2006 14:06
Re: Wow! :-)
By: horny on Sat, 22 July 2006 04:56
Re: Wow! :-)
By: Damir on Sun, 23 July 2006 07:14
Re: Wow! :-)
By: horny on Sat, 29 July 2006 03:59
By: horny on Sun, 13 August 2006 04:04
By: Damir on Sun, 13 August 2006 16:00
By: horny on Wed, 16 August 2006 14:43
By: Damir on Thu, 17 August 2006 07:45
By: red on Wed, 01 August 2007 06:24
Current Time: Thu Nov 19 05:38:25 CST 2026
