Home » Audio » Group Build » tried the 6688
Re: Amperex and Phillips E180F [message #31908 is a reply to message #31907] Sat, 24 June 2006 09:14 Go to previous messageGo to previous message
Hej, dobro dosao na forum! Pretpostavljam da si iz Hrvatske ili iz neke druge ex-YU republike (Bosna?), drago mi je da ima jos lampaskih samograditelja. Ako nisi bas vjest sa engleskim, ja cu prevoditi tvoje poruke, zbog drugih - ipak je ovo USA / internacionalni forum...
Hvala na informaciji, kako rekoh - imam samo jedan par Philips-ovih E180F, ta lampa je visoka skupa sa pinovima samo oko 43 mm...
The English translation of Rajko`s message:
"Damir, Amperex E180F is a different than Philips or Siemens. It has completely different internal structure, the reason for about 1 cm taller glass envelope, no gold pins.
I didn`t try them yet, but I have no much confidence in Amperex.
I just prepare myself to build SE 300B, I have 300B`s from ex 300B-PP.
Greetings."
Previous Topic: SE 300B Project, Part 12 - C3g driver
Next Topic: C3g & D3a
Current Time: Fri Oct 23 01:54:51 CDT 2026
