Home » Audio » Group Build » tried the 6688
Re: tried the 6688 [message #31906 is a reply to message #31905] Wed, 21 June 2006 00:17 Go to previous messageGo to previous message
Strange - as I described it, my D3a and E180F tubes sound very similar, D3a a bit more "rough", and E180F little more "smooth". But both have a dynamic, open and direct, powerfull sound.
I think that with choke load you should use bypassed cathode, if not - rp of the triode goes up, not a good thing in combination with L and Cw of the choke (both frequency extremes). Maybe try the bypass first, say 100µF-220µF.
But, I noticed in 6SN7 test that, although similar, there`re differences between the tubes of the same type. Some sound "big, open, clean", and other more in "blanket, compressed, warm, unfocussed" way.
As I said, my pair of E180F is NOS Philips, unfortunately didn`t try other types.
Previous Topic: SE 300B Project, Part 12 - C3g driver
Next Topic: C3g & D3a
Current Time: Sun Nov 01 06:07:15 CST 2026
