Home » Audio » Group Build » tried the 6688
Re: tried the 6688 [message #31904 is a reply to message #31903] Mon, 19 June 2006 00:02 Go to previous messageGo to previous message
Forgot to add - check for oscillations, I have a problem with all those high-gm tubes. Use g1 stopper, g2 stopper (g2 to anode), and use both cathode connections - I use two resistors, but one Rk+wire bypass to other cathode pin worked, too. Where you connected g3?
Somehow I can`t believe that you and I get totally opposite results?!
Previous Topic: SE 300B Project, Part 12 - C3g driver
Next Topic: C3g & D3a
Current Time: Sun Nov 01 05:04:37 CST 2026
