Home » Audio » Group Build » gapped Iron
Re: gapped Iron [message #31874 is a reply to message #31873] Mon, 24 April 2006 13:01 Go to previous messageGo to previous message
Old Brown Eyes is currently offline  Old Brown Eyes
Hey Damir and Doug,
At the risk of becoming an unmentionable name here wouldn't trying to keep the grid chokes inductance more or less a constant insure the very problem you are trying to cure? Namely that if the inductance is a constant then the load is a frequency dependant variable. Instead if the inductance is high enough to swamp the load resistor and tube's internal resistance at low hertz and then falls in a more or less linear manner so that the actual impedance the tube works into is a constant wouldn't that be best? Off the top of my head 1,000 henry at 20 hertz would be 125K but at 20kHz only 1 henry is needed to have the same reactance. Of course there are more things to consider than just the inductive reactance but I think you get the gist of my question. Now I have no idea just how the reactance falls as a function of frequency but offhand to keep a constant load I come up with roughly needing 1/50th @ 1kHz as at 20 hertz and 1/1000 @ 20kHz as at 20 hertz.
Russ
Previous Topic: cathode followers: minimum input impedance configuration?
Next Topic: But I'm still on step 9...
Current Time: Sun Nov 01 05:03:49 CST 2026
