Home » Audio » Group Build » Say Doug; how would you go about..
Re: Look here for 12B4 line stage info! [message #31809 is a reply to message #31808] Fri, 10 March 2006 04:02 Go to previous message
Hey-Hey!!!,
The PS is a CRCRC with a shared first C then branched. Power Iron is a 261G6 which is ~$30. 125-0-125 at 130 mA, plus a 2A 6.3 winding.
I never built this with 12B4 and CCS, so I don't know what the gain *MIGHT* have been. It has a 50k volume pot with a 75k shunt resistor so it is gain-reduced anyway.
Don't worry too much about the B+, with 10k plate loads, there is no dissipation issue until it's over 400 anyway. 4 or 5( or maybe 6 ) LED's will be fine too. Just make sure your plate loads are up to the task. Remember, the output voltage is going to be less than 10 p-p, so we don't need a lot of cathode bias....back to less LED's no?
cheers,
Douglas
Previous Topic: CCS Failure Possibilities
Next Topic: Inductor capazitance
Current Time: Sat Nov 07 08:11:57 CST 2026
