Home » Audio » Group Build » CCS Failure Possibilities
Re: whaaaaaat? [message #31795 is a reply to message #31794] Fri, 03 March 2006 12:28 Go to previous messageGo to previous message
It's not so much about being worried; it's more about knowing all potential risk factors ahead of time. So you say if the Mos-Fet fails then it doesn't affect the tube? Because if that is the case then there is nothing to worry about.
There was some posts on the net suggesting that there could be a problem should that happen; putting the entire B+ across the tube.
Previous Topic: 300B SE Project, Part 7 - Common cathode 6C45Pi triode driver
Next Topic: Say Doug; how would you go about..
Current Time: Sat Nov 07 08:26:50 CST 2026
