Home » Audio » Group Build » Anyone use 6S45P with 12B4A concertina for PP 7591A or 6L6?
Re: Anyone use 6S45P with 12B4A concertina for PP 7591A or 6L6? [message #31782 is a reply to message #31780] Tue, 28 February 2006 13:31 Go to previous messageGo to previous message
No, I didn`t, but if you don`t need the NFB than you can use something like this - 5687 concertina, works with E182CC, too. 50k resistors (R7,R8) are actually grid-leak resistors of the output tubes. With them, and 5687 you can get about 2x27Vrms out with 2Vrms input, it`s about 2x38Vp, or about 5dB of "headroom" for -22V (needs max. 22Vp) biased 7591. With E182CC you can get about 2x32Vrms out(2x45Vp) - enough even for 6L6.
The current through 1st and 2nd stage is 10,5+10,5mA. I used something like this in my PPP monoblocs, and when I find some time I`ll put the CCS in the place of 27k resistor, stay tuned...
Previous Topic: choke measurements
Next Topic: Seduced by the Dark Side
Current Time: Fri Sep 25 15:22:10 CDT 2026
