Home » Audio » Group Build » 300B SE Project, Part 7 - Common cathode 6C45Pi triode driver
Re: 300B SE Project, Part 7 - Common cathode 6C45Pi triode driver [message #31767 is a reply to message #31766] Sun, 26 February 2006 11:51 Go to previous messageGo to previous message
Harder without oscilloscope, but there`re some symptoms - in bad cases there`re hum present and unstable work of the circuit. Oscillating tube, for example would "pull" large current. In "moderate" cases, probably "strange" sound - glassy, strange distortion, especially in high frequencies, rustle and dry... When you touch or move some parts/wires, you hear the change in this symptoms/sound. Every wire is antenne, inductance and capacitance, and when you have the gain you have oscillator... It can be a tough problem, depends of the layout...
Previous Topic: Ping Doug
Next Topic: CCS Failure Possibilities
Current Time: Sat Nov 07 08:40:10 CST 2026
