Audio
Bias supply
Re: Bias supply
message #31718
is a reply to
message #31717
Wed, 25 January 2006 23:28
Damir
May 2009
The new schematic - 30V AC PT and voltage doubler rectifier with two outputs. Larger neg. voltage for the 2A3 bias, and lower for the CCS.
http://www.audioroundtable.com/GroupBuild/Projects/Galahad_Bias_Doubler_Schematic.pdf
Message index
Bias supply
By:
PakProtector
on Sat, 21 January 2006 06:30
the Schematic
By:
PakProtector
on Tue, 24 January 2006 09:55
Re: the Schematic
By:
Damir
on Tue, 24 January 2006 15:21
Re: the Schematic
By:
2wo
on Tue, 24 January 2006 16:36
Re: the Schematic
By:
PakProtector
on Tue, 24 January 2006 17:03
Re: Bias supply
By:
Manualblock
on Wed, 25 January 2006 10:01
Re: Bias supply
By:
Damir
on Wed, 25 January 2006 13:49
Re: Bias supply
By:
Manualblock
on Wed, 25 January 2006 16:11
Re: Bias supply
By:
Damir
on Wed, 25 January 2006 23:28
Re: Bias supply
By:
Manualblock
on Thu, 26 January 2006 07:59
Re: Bias supply
By:
Damir
on Thu, 26 January 2006 11:17
Re: Bias supply
By:
Manualblock
on Thu, 26 January 2006 12:40
Re: Bias supply
By:
Damir
on Thu, 26 January 2006 13:04
Re: Bias supply
By:
Manualblock
on Thu, 26 January 2006 15:03
Should you consider Anything involving high voltages novice work?
By:
Old Brown Eyes
on Thu, 26 January 2006 13:14
Re: Should you consider Anything involving high voltages novice work?
By:
Manualblock
on Thu, 26 January 2006 15:02
Latest Seth schematic
By:
Old Brown Eyes
on Fri, 27 January 2006 05:55
Re: Latest Seth schematic
By:
PakProtector
on Fri, 27 January 2006 09:19
By:
Manualblock
on Fri, 27 January 2006 09:22
yes it does...
By:
PakProtector
on Fri, 27 January 2006 13:30
Re: yes it does...
By:
Jeff Lessard
on Tue, 31 January 2006 12:53
Re: yes it does...
By:
PakProtector
on Tue, 31 January 2006 16:47
By:
PakProtector
on Thu, 26 January 2006 18:08
patience...
By:
PakProtector
on Thu, 26 January 2006 18:18
Re: patience...
By:
Manualblock
on Thu, 26 January 2006 20:56
Galahad Amp
By:
on Fri, 27 January 2006 09:11
Re: Galahad Amp
By:
Manualblock
Re: Galahad Amp
By:
PakProtector
on Fri, 27 January 2006 09:27
Re: Galahad Amp
By:
on Fri, 27 January 2006 10:37
Re: Bias supply
By:
2wo
on Sun, 29 January 2006 18:22
ooooohhhh! neat
By:
PakProtector
on Tue, 31 January 2006 17:13
simple circuits
By:
PakProtector
on Wed, 01 February 2006 17:42
MOSFET D-S voltage
By:
PakProtector
on Wed, 25 January 2006 14:42
In the proper Tube tradition...
inductor winding and bobbins
Thu Nov 26 07:09:33 CST 2026
