Home » Audio » Group Build » The shunt capacitance of grid and anode chokes
oscillation [message #31582 is a reply to message #31563] Wed, 07 December 2005 16:31 Go to previous messageGo to previous message
Keep one thing in mind, oscillation is *NOT* a class A affair. It runs to extremes, usually to grid current...
If you have the grid of any stage running to positive values, the sonics are going to suffer for some non-zero recovery period. This period will be longer than the one oscillation, and is one mechanism by which a 22 MHz oscillation can make itself known.
I tried a high gm cascode and found it singing along with 20V peak-peak of 22 MHz oscillation. Resistive dampers cured it, and the circuit souded better. No easy way to be sure you've got things under control save to measure carefully.
cheers,
Douglas
and speaking of high gm, how 'bout a 100,000 mA/V device?
Previous Topic: Merlin Iron connection
Next Topic: Resistor choices for SV811 project
Current Time: Fri Oct 16 00:38:53 CDT 2026
