Home » Audio » General » New DIY modded FM tuner reviews on TIC
Re: New DIY modded FM tuner reviews on TIC [message #3135 is a reply to message #3134] Tue, 23 May 2006 09:43 Go to previous messageGo to previous message
3moons is currently offline  3moons
Hi Wayne,
As far as electrolytics in a transistor audio signal path go, I personally prefer, Sanyo OS-CON caps. I've now replaced stock caps and/or Black Gates in my personal tuners and in several Scott Nixon DAC's (after the tube). But for my favorite Nixon DAC I did use polypropylene coupling caps. It had to be built in a larger chassis of course. Having said all that, one friend preferred the Black Gates in a tuner over Sanyo's. But for me, the OS-CONs sound a little sweeter. A little less bright at the top. The next guy may want that. I used a mix of Sanyo's and Nichicon Fine Gold's in the Kenwood KT-5020 because I was working with parts (and correct values) available off my work bench. In the direct signal path I used two Fine Gold's for coupling before the output buffer, 10uf, the correct value per the schematic. After the buffer I used four Sanyo's for coupling of a larger value than stock 22 uf. I would have used all Sanyo's but didn't have any at 10 uf. Also change out three 'decoupling caps' with Fine Gold's. I haven't built a tuner using all Fine Gold's. So I guess I haven't really answered your question! Sorry Wayne. 8:-) jim...
Previous Topic: DIY RCA interconnects
Next Topic: Yamaha M-50
Current Time: Fri Oct 16 21:03:54 CDT 2026
