Home » Audio » Group Build » Dear Manualblock
any news yet? [message #31271 is a reply to message #31268] Sun, 21 August 2005 04:55 Go to previous message
Thrint is currently offline  Thrint
Have you been under the hood?
The circuit is simple enough that there can't be too many troubles.
On to the FMEA...
Hum can be from two sources, the plate supply or the input. THe cathode counted as an input.
If it is the plate supply, I suggest MOSFET failure. It is not likely that a working CCS lets enough hum through. Check plate voltage, and if possible measure out-of-circuit gate-source resistance. it should be infinite, excepting some capaciatance( but we're talking DC...)
If it is the input, there are more troublesome things to check. grounding is too wide a net, look at individual ground points, and check physical integrity. Of lesser likelyhood, a filament-cathode short would cause hum of some, given that we're not running pure DC.
regards,
Douglas
Previous Topic: The DRD 45 breadboard
Next Topic: The DRD update
Current Time: Sun Nov 01 03:26:14 CST 2026
