Home » Audio » Group Build » Power Tx question - Dumb question
Re: Power Tx question - Dumb question [message #31161 is a reply to message #31159] Fri, 10 June 2005 14:50 Go to previous messageGo to previous message
You know I am probably not qualified to answer that; I never really spent serious time with either amp using that tube. You should look at the SP amp though; because as Akhilesh says in his post, the DRD is just a way to try and save on OPT's. And I tend to agree with his point. The SP is more like a normal design and heck; if it is good enough for Gordon Rankin.
There is no free lunch.
Previous Topic: Multiple caps vs. single cap?
Next Topic: Group build OTL?
Current Time: Thu Nov 19 04:40:37 CST 2026
