Home » Audio » Group Build » SE or PP?
that's still wide open [message #31061 is a reply to message #31060] Wed, 20 April 2005 07:15 Go to previous messageGo to previous message
this one:
minimum 20 watts; triode PP with tube rec and as far as power supply choke input with B+ as high as is required to obtain that big sound
I'll assume we're still full-on Class A. This 20W minimum still puts us in the moderate 845 B+ territory. Not exactly a bad thing.
I have been itching for a serious experimenter's power TX. Multiple taps on the primary like Varian requested from Paeco. Change the primary hook up to yeild 500-800V after an L-C filter Full-Wave with vacuum or Hg-vapour dioides. 300 mA deliverable at even the highest voltage. Probably ~$250 each. Slightly less if several are ordered.
On the 813 thing, I have not yet heard any, just an assumption I can get them to work well for me. The PP 845 is complex enough, and I am sure of that one. And I have OPTx's nearly tailor made for it. This is not a small thing to consider, availability of reasonably priced excellent OPTx.
As a swing for the fence( with a paid-off pitcher ), the PP845 amp is quite appetizing. 30W ought to be available fairly conservatively, and with no exotic parts. If it weren't for the 813's challenges, I'd build one next.
regards,
Douglas
Previous Topic: New PCB for the CCS
Next Topic: line stage for VTV
Current Time: Thu Nov 19 03:03:12 CST 2026
