Home » Audio » Group Build » SE or PP?
Re: well, it sort of goes like this... [message #31060 is a reply to message #31059] Tue, 19 April 2005 21:47 Go to previous messageGo to previous message
sounds good. The thing is you have heard all the amps so therefor how about this; What would you choose that would be interesting for you to realise that provides minimum 20 watts; triode PP with tube rec and as far as power supply choke input with B+ as high as is required to obtain that big sound such as you describe with the 813's?
And whatever sounds personally intriqueing. I think you can get some dedicated experimenters here now that Guinevere turned out so well.
As little feedback; or even variable feedback as possible. Set a reasonable limit of say 800$ in parts.
Construct it in sections that can be individually tested before moving on to the next section. E-Linear with seperate DC filament supplies.
Start with the PS maybe; whatever seems best. Draw up a common top-plate template that can act as a reference for other projects but provide some uniformity between samples. Group buy whatever parts we can.
Just a thought, J.R.
Previous Topic: New PCB for the CCS
Next Topic: line stage for VTV
Current Time: Thu Nov 19 03:03:07 CST 2026
