Home » Audio » Group Build » Location of Selector Switch in Preamp
Re: Location of Selector Switch in Preamp [message #30877 is a reply to message #30875] Mon, 07 March 2005 16:06 Go to previous message
Hey-Hey!!!,
being a one-source builder sort of simplifies tha one for me...
If you put the switch right next to the inputs, you can run a single wire to the volume knob. If this changes the amount of noise pick up, I am not sure.
I'd consider the neatness and simpler is probably the better way to go. Short wire to teh switch, single to the volume control. That's my opinion anyway.
regards,
Douglas
Previous Topic: the Amp
Next Topic: Guinevere wired and ready.
Current Time: Fri Oct 16 04:05:14 CDT 2026
