Home » Audio » Group Build » Filament Caps
Less ripple w/10k uF [message #30816 is a reply to message #30815] Fri, 04 March 2005 08:47 Go to previous messageGo to previous message
Ran a PSU simulation using 4.7k vs. 10k uF in the RCRC heater. 10k gives a lot less ripple if used in the first position (the one closest to the diodes) A change in ripple was not even noticed if the value was increased in the second position (cap closest to load) From this, you might want to hold off and use the 10k's. It sure looks like you'll be better off.....Colin
Previous Topic: Mounting Coupling caps
Next Topic: More amp design considerations
Current Time: Sat Nov 28 18:41:41 CST 2026
