Home » Audio » Group Build » LEDs light - can I assume CCS is wires properly?
Re: Yeap, blown fuse [message #30771 is a reply to message #30766] Tue, 01 March 2005 05:16 Go to previous message
actually, I like Colin's method. Never thought of doing it that way. There is no danger, save for heat generation, as the CCS is dropping all of B+. For short period of time, it shouldn't pose a problem.
Just be sure you don't try this from the mu output, as damage couldbe done the mosfets, and there is no way to get an real meanurement w/o including R3.
I am going to try this on my valve pre-where I can't test w/ a 9V out of circuit.
Thanks for showing me this method.
regrds,
Douglas
Previous Topic: Guinever done
Next Topic: Guinever underside
Current Time: Fri Nov 06 01:42:58 CST 2026
