Home » Audio » Group Build » Adjusting R3
Re: Adjusting R3 [message #30746 is a reply to message #30726] Sat, 26 February 2005 17:08 Go to previous message
Hey-Hey!!!
For this you ignore the mu output. Put the ammeter or sensing resistor in series with a 9V battery. + to the upper drain and - to the plate end of R-3. Watch the meter and adjust until the CCS is passing the 15 mA of current.
If you use a sense resistor, use Ohm's Law to determine curent. If you use the mA function then you'l get the reading directly. It will probably come in when R-3 is ~150R or so.
Call if you wish, I will talk you through it.
regards,
Douglas
Previous Topic: Anything of interest - ebay tube lot
Next Topic: hi Damir and all
Current Time: Thu Nov 19 13:33:58 CST 2026
