Home » Audio » General » Time for GPAF!
Also [message #3071 is a reply to message #3069] Tue, 09 May 2006 17:00 Go to previous messageGo to previous message
I forgot to mention this enclosure is very easy to build because you are starting with pre cut 11.25" wide mdf boards. You cut all the panels exactly 36", then you trim four of them down to 9.75" for the front and back panels. The other four you use in their full 11.25" width for the sides. The top and bottom panels are already the correct 11.25" depth, so all you have to do is to cut them to the required 8.25" width. My yard charges 70 cents/ft for the precut mdf boards, so the total for the 32' needed to build two enclosures is just south of $25.
Previous Topic: WSOTT - Cinci edition - July 15
Next Topic: fostex up 203 super
Current Time: Wed Oct 21 19:43:44 CDT 2026
