Home » Audio » Group Build » Rs Filament supply
Re: Rs Filament supply [message #30696 is a reply to message #30686] Fri, 25 February 2005 18:31 Go to previous messageGo to previous message
The way I'm doing it is to wire both Tx's together in parallel to two terminals on a barrier strip. The power comes in after the fuse and switch and neurtal is hooked to one terminal and hot is hooked to the other. On my barrier strip, the center terminal makes contact with the chassis and is used as the earth (green wire).....Colin
Previous Topic: oil caps
Next Topic: The Poinz!
Current Time: Thu Nov 05 21:51:48 CST 2026
