Home » Audio » Group Build » Going to build Gunevere with you guys...
Re: Eiclones? [message #30642 is a reply to message #30641] Tue, 22 February 2005 07:25 Go to previous messageGo to previous message
Hey-Hey!!!,
I don't think the ForePlay comes with Photo-flash caps. I think they are Panasonic TSHA.
The circuit of those amps uses the tertiary widing in the OPTx for cathode feedback. Cascaded diff amps, a 6BL7 to a 7236 was the last combo I tried. It sounded great. The OPTx was definately the limiting factor. I am designing a replacement on a smaller core with a better interleaving schedule. I am aiming for the Quad II 9 3/8:1 ratio. It is taking a bit of iterating, that's for sure.
Remember, the flash caps are a budget and space expediency, I don't think they are designed for continious charge storage. They seem to survive it adequately( and I can put together a few hundred uF from a parallel connection ). If I didn't already have most of a chassis ready to go, I'd use the motor run caps I have in a box in a second.
regards,
Douglas
Previous Topic: supplier dealings
Next Topic: Tertiary winding OPTx windings
Current Time: Thu Nov 05 12:04:10 CST 2026
