Home » Audio » Group Build » By Sunday night...
Re: By Sunday night... [message #30581 is a reply to message #30580] Fri, 18 February 2005 14:17 Go to previous messageGo to previous message
I think you overestimate us. I am still waiting for parts to arrive! Maybe by the following Sunday. See; you have the up-front knowledge to know what to order. We had to wait for the final revision before we could even place those orders. The final revision wasn't even established until about a week and a half ago; then finding all the different places to place orders. I have 5 different parts sources not including RS and other local houses. Some people ordered parts that were not part of the final revision so hence scrapped.
And to be truthfull; until I start to wire it up; I am not sure if I have everything I need. The original BOM has changed several times. T; allow me to offer up a small observation from my own perspective. When you guys answer a question; you give first;
The answer;
Next you say something along these lines(I am not quoting directly)
"You need blah blah blah; O'kay.. but you can also do this; this or this!" Those also rans kill me! By the time you get to the third also possibility I am lost. I am so busy trying to figure which choice to go with that my head explodes.
Please don't take this as a criticism; it's not. Just an observation.
The reason I personally haven't had any questions for you is I don't know what to ask until I start building, then I will have plenty!
I will admitt those giant size caps look great; big trans/big caps/big tubes=BIG SOUND.
How about a coupla simple voltage test points and small tutorial on how to do them safely.
How about a buss bar for star grounding made from 14ga. romex?
A example of what you're using for selector switch and which 4.7k filter caps do you use. Thats the last part I should need.
Previous Topic: two tubes instead of one
Next Topic: supplier dealings
Current Time: Thu Nov 05 12:57:42 CST 2026
