Home » Audio » Group Build » Silver Lining
anectdotal evidence [message #30572 is a reply to message #30571] Wed, 16 February 2005 18:07 Go to previous messageGo to previous message
On an olde Triad Tx there is the current specification: 150 mA condenser input, 200 mA choke input.
33% increase for using the L-C filter.
If we assume it can deliver its rated 100 mA into a cap input filter, it will have no troubles with a choke input.
You gave me a general size of the Iron. It'll be fine. Perhaps run harder than I would do with a clean sheet design, but adequate.
regards,
Douglas
Previous Topic: Capacitors
Next Topic: Psud II / PC problems
Current Time: Thu Oct 15 23:08:26 CDT 2026
