Home » Audio » Group Build » Silver Lining
Re: Silver Lining [message #30570 is a reply to message #30568] Wed, 16 February 2005 12:10 Go to previous message
I must say that I like "overdimensioned" PTs, "Guinevere" PT is maybe more suitable for monobloc SE 2A3 amp (400V taps into LCLC gives about 310V - OK for the "classic" OP: 250V/-45V/60mA + CCS or choke loaded driver).
But, if we use another OP, say 300V/50mA/-59V, then we can (probably) make it. But, driver needs some current, and about 400V B+...
Anyway, let`s see:
Ra=(4,2*59)/0,05 - 800 = 4156 Ohms, lets say "standard" 4k, then:
Ua=(mu*Ugk)/(1+rp/Ra) = 146Vrms, and:
Pa=Ua^2/Ra=5,3W
Available current swing give us the power: Pa=Ia^2*Ra=5W
And Raa = 2Ra=8k, Paa=10W - losses are about 10-15%, and we can expect max. power Pout~8,5W.
If we use higher, more "relaxed" load Raa=10k (lower distortion, higher DF, but lower power), we can expect about Pa=9,1W, and Pout~7,7W. Not bad (theoretically)?
Previous Topic: Capacitors
Next Topic: Psud II / PC problems
Current Time: Thu Oct 15 23:08:00 CDT 2026
