Home » Audio » Group Build » PCB for the CCS
Re: PCB for the CCS [message #30546 is a reply to message #30544] Tue, 15 February 2005 12:12 Go to previous messageGo to previous message
Who needs them?:-) Large part of this hobby is pleasure when you build something all by yourself - allright, "home made" PCB probably won`t looks too proffesional, but so what?
You can buy PCBs in electronic store, adjust dimensions of the little board and traces to your components (little planning in 1:1 on the paper), clean the Cu, then with alcohol-marker draw the traces, and paint them with your favorite nail-polish (avoid glittering one, just ordinary :-)). Buy Fe-III-Chlorid christals (el. store, too), put them in the PVC glass of water, put the board in and wait. "Mix up" a little, it can last a few hours - but then the unprotected Cu "go away", clean the lacquer with polish remover (acetone). Use ~0,9mm bore, few holes and that`s it. Use rubber gloves. Check the traces before and after soldering on little particles and dirt between the traces. Good luck!
Previous Topic: transformer
Next Topic: Capacitors
Current Time: Sat Nov 14 04:00:49 CST 2026
