Home » Audio » Group Build » Capacitors
Re: Capacitors [message #30542 is a reply to message #30540] Tue, 15 February 2005 07:26 Go to previous messageGo to previous message
Hey-Hey!!!,
ON the peanut tubes, the 5687 is the same size as an AU7/AT7/AX7 ( heh-heh-heh...).
There is one more thing y'all may want to do. Prepare for adding a second 9-pin socket so that you can run the 12B4 with its lower gain.
The mods are simple: 6 LED's instead of two.
and of course the second socket. Heater current for two at 12.6 is .6A instead of .45 for the 5687. Minor tweaks of the supply *MIGHT* be required if you want to hit the heater voltage +/- 1%
regards,
Douglas
Previous Topic: PCB for the CCS
Next Topic: Silver Lining
Current Time: Sat Nov 14 04:02:45 CST 2026
