Home » Audio » Group Build » Capacitors
Re: Capacitors [message #30529 is a reply to message #30527] Mon, 14 February 2005 17:33 Go to previous messageGo to previous message
I just recieved my coupling caps and Trans. so tommorrow I start lay-out. Were you able to use Damir's photos for your CCS boards?
When you say boards; do you mean PC boards and if so where did you get them etched?
You never stated if you got the red LED's or where you got them.
I'm trying to form a mental pic of the set-up over the I-Beams. What exactly do you have tied to the beam?
If you ended up using the wood side panels how are mounting your RCA inputs?
Previous Topic: PCB for the CCS
Next Topic: Silver Lining
Current Time: Sun Oct 25 12:55:46 CDT 2026
