Home » Audio » Group Build » Capacitors
Re: Capacitors [message #30527 is a reply to message #30526] Mon, 14 February 2005 16:56 Go to previous messageGo to previous message
There's going to be a lot of weight when things are done - that's for sure. I'm using an L-channel under the chassis. This will be placed in under the front mounting holes of botn Tx's and the choke, thus fewer scwers poking through the top (thanks GarMan).
Have you started to lay out the CCS? I ran into a concern last night the way I have things on the PC board. The output to the coupling cap and the power (B+ from MOSFETs) are pretty close together, about 1/2". I'm hopeing I'm not going to run into any problems with noise. I think this is where the shielded cable is really going to come in handy......Colin
Previous Topic: PCB for the CCS
Next Topic: Silver Lining
Current Time: Sat Nov 14 04:02:44 CST 2026
