Home » Audio » Group Build » Stoetkit arrived!
Re: Exposed Screws [message #30398 is a reply to message #30385] Fri, 04 February 2005 17:41 Go to previous messageGo to previous message
Man, you're killing me. I hope I have enough holes (7) on the terminal strips that I can get away with 3-4 strips all together. I'll try not to drill new holes, but simply use existing screws on the tube sockets or chokes.
My copper is a little thinner than I would like, and I have some concern about the weight. With two trans and 2 chokes, we're looking at around 12-15 pounds. I do have a length of 1/4 x 1/4" copper l-channel that I'm going to solder on the bottom for support, so if worse comes to worse I can mount off of these as well.
My biggest problem is keeping the other metallic materials from touching the copper. The different metals in contact will tend to corrode one, in this case the copper. I'm going to be very careful in the mounting process by using lots of nylon washers as spacers......Colin
Previous Topic: Heater PS schematic
Next Topic: Att: Damir.
Current Time: Tue Oct 06 02:20:08 CDT 2026
