Home » Audio » Group Build » RIAA preamp?
Re: RIAA preamp? [message #30377 is a reply to message #30376] Thu, 03 February 2005 14:46 Go to previous messageGo to previous message
Not so sure what you mean, maybe shielded cable? I`d build it close to the input pot, just a few cm of wire. Tube socket can be PTFE material or so + tube shield...
I posted this schematic in hope that some discussion can be made... at the end, maybe someone actually build it and try it... I hope that direct coupling between the stages have more advantages then flaws... then cathode decoupling cap C3 (220uF/160V-probably electrolitic) hasn`t large negative impact on sound (can be avoid with active load and Mu-out), etc.
Previous Topic: 6v6v6
Next Topic: Does anyone want me to go thru grounding? (nt)
Current Time: Mon Nov 09 06:19:57 CST 2026
