Home » Audio » Group Build » Test Points
Voltage? [message #30279 is a reply to message #30278] Tue, 25 January 2005 13:29 Go to previous messageGo to previous message
Hey-Hey!!!,
Since this resistor is across the entire B+, it should be able to stand worst-case. Say 500V will be plenty.
As to power, V-squared over R will give you power. Using 200V for the V-term will give you a value to double. We don't want the thing getting too hot. 200 squared is ~40k so about a watt is reasonable estimaate of actual heat. A 5W ought to be easy enough to source.
regards,
Douglas Piccard
Previous Topic: trade DN2340 For tube sockets?
Next Topic: trans order
Current Time: Fri Nov 06 03:09:14 CST 2026
