Home » Audio » Group Build » Test Points
Re: Test Points [message #30261 is a reply to message #30226] Sun, 23 January 2005 19:21 Go to previous message
Hey-Hey!!!,
Damir has got the anticipated voltages pretty close. Go to the Duncan amps TDSL and get the data sheet for the 5687( probably have to get the 'WA' version, it's the same ).
Block off the curves past ~200 volts. Draw a horizontal line at ~10 mA. Interpolate a bit to generate a grid curve at ~3.7 volts. What plate voltage do the load and grid lines cross? By the curves in my sheet, it looks like ~90V. Perhaps a third LED to raise the plate voltage to ~120 might be a good idea...try both and see. You can clip lead a short of one of the LED's if you want to put in three the first time.
regards,
Douglas
Previous Topic: trade DN2340 For tube sockets?
Next Topic: trans order
Current Time: Fri Nov 06 03:08:51 CST 2026
