Home » Audio » Group Build » Test Points
Re: Test Points [message #30232 is a reply to message #30226] Sun, 23 January 2005 02:00 Go to previous messageGo to previous message
B+ is about 200V, anode voltage (between anode and ground) is about 110 V, cathode voltage (voltage drop through 2 red LED, between the cathode and ground) about 3,5V. Most of the voltage drop from B+=200V to the Ua=110V is through the upper mosfet, lower would drop maybe Uds~1,5V or so. Upper mosfet must be mounted on the small heatsink. Use termal-conductive insulation.
Voltage through "current set" resistor (~100 Ohms in the schematics, use trim-pot of 500 Ohms - 1k, from the most resistance to the lower resistance) by Ohms Law is U=R*I.
Be carefull, high voltages are dangerous. PS cap can be charged for a long time after switching off, use resistive bleeder. Last time I forgot this (270uF charged at 430V, nice electro-shock)...
Previous Topic: trade DN2340 For tube sockets?
Next Topic: trans order
Current Time: Fri Nov 06 03:08:47 CST 2026
