Home » Audio » Group Build » Who?
PSUDii say-eth... [message #30208 is a reply to message #30193] Fri, 21 January 2005 19:27 Go to previous messageGo to previous message
Hey-Hey!!!,
On the resistor to force a critical curent load. I went in playing with PSUDii and a resistive load. 250 volts in, 20 Hy and fiddled with resistor values. I got up to 45kOhm and did not cross 300 volts on a long term basis, and figured it was plenty to keep things in check, and from behaving like a cap input supply.
V-squared over R at 300 volts shows dissipated power to be 2 watts on a 45k resistor. A 5W ought to run cool enough. 5 9k1 1/2 watt will also work if you feel like experimenting. Since B+ is ~200, continious dissipation will be less than a watt for a 45k resistor.
regards,
Douglas
Previous Topic: 10 ma max draw.
Next Topic: Chassis
Current Time: Fri Nov 06 00:45:57 CST 2026
