Home » Audio » Group Build » Anybody starting to build yet?
Re: Anybody starting to build yet? [message #30103 is a reply to message #30102] Thu, 13 January 2005 08:19 Go to previous messageGo to previous message
I agree, John. I sort of had a thing for an all-tube circuit from the start. Having both options is cool, but I'll probably build mine as an all-tube circuit.
Transformer rectified power supplies are incredibly simple. You can use a single diode as a half-wave rectifier and filter it as well as possible. Or you can use a pair of diodes to form a full-wave rectifier.
With four diodes, you can form a bridge. That's what Douglas was doing with the tube dual diode and the pair of solid state rectifiers. He was making a bridge rectifier.
I'll probably just go with a dual diode full wave rectifier and a filter. I'll probably use a large choke instead of the constant current source too. Then I can always change the circuit later and do Douglas's design for a mod. That's kinda how I did my Paramours too - First as the original plans showed having no CCS, and then later I added them and compared the two.
Previous Topic: Guienevere; PS
Next Topic: Power TX...special
Current Time: Thu Nov 19 09:26:05 CST 2026
