Home » Audio » Group Build » A suggestion for chassis
Re: A suggestion for chassis [message #30100 is a reply to message #30099] Tue, 11 January 2005 17:43 Go to previous message
Your work looks pretty darn good from here. Nice idea; the shadow boxes. Maybe you can notch a groove in the rear with a router for mounting connectors; stabilise the unit with corner clamps and a vise and route out a groove in the center of the rear panel deep enough to allow a standard RCA jack to clear the frame. I have seen people drill oversize holes for mounting jacks in the rear panel then attaching a pre-drilled brass plate over the section of panel where the holes lay and mounting connectors on the brass or smoke colored acrylic also works.
Previous Topic: Guinevere PT options
Next Topic: Guienevere; PS
Current Time: Thu Nov 19 09:09:36 CST 2026
