Home » Audio » Group Build » Here's Guinevere
notes, and a correction. [message #30069 is a reply to message #30064] Wed, 29 December 2004 15:17 Go to previous messageGo to previous message
Here are some answers:
R3 is a 500k. it serves very little purpose, but is good to put in to take care of smallDC when in operation
R1 is a carbon comp, quarter of a watt. Mouser has them cheap from XIcon. value is between 510R and 1k. I have used 510 with no troubles, but if you find 1k to be a useful thing, bet them in qty...
S2 is the Mute, short it out and you won't have to worry about a 'thump' on start up.
There is a mistake!!!!
P1 in the source-gate circuit should be configurd as a variable resistance, tie the end at the plate to the wiper and we'll be fine.
regards,
Douglas
Previous Topic: Tranny Order
Next Topic: Potentiometer
Current Time: Fri Oct 16 17:15:06 CDT 2026
