Home » Audio » Group Build » what in the hell is a 5861?
Re: alright then... [message #29986 is a reply to message #29985] Tue, 21 December 2004 19:59 Go to previous messageGo to previous message
Hey-Hey!!!,
I like the 5687 a lot. I will let you know about the next iteration when I have it built. In the mean time, I would caution you about trying Mercury vapor diodes like 816 and 83 until you are a bit more comfortable with the undeside of your own creation.
The other sticking points to a later iteration don't seem like sticking points anymore to me. Build the simplest one and they seem to evaporate with familiarity and practice.
The linestage sounds good. I have not listened to it with the single MOSFET plate load CCS in a ling time. It is easy to modify it to a cascode circuit later. The single *IS* simpler and easier to deal with at first. I would not have suggested it if I were not confident in the result.
regards,
Douglas
Previous Topic: Welcome!
Next Topic: Naming the 5687 Linestage...
Current Time: Sun Nov 22 23:51:01 CST 2026
