Home » Audio » Craftsmen » amp enclosure
Re: amp enclosure [message #29902 is a reply to message #29901] Mon, 26 March 2007 09:06 Go to previous message
As you've discovered, if you cut the rabbet after gluing up the box you're left with the rounded corners.
Just use 1/2" or bigger chisel to cut the square. Use the extra width of the flat edge to index against the already cut side of the rabbet. Alternate your cuts from one side of the corner to the other so as not to have a split.
Previous Topic: Got me a lathe!
Next Topic: Lathe Madness
Current Time: Sat Nov 07 00:01:39 CST 2026
