Home » Audio » Craftsmen » Newbee Tools
Re: Spend the money on precision [message #29900 is a reply to message #29899] Sun, 25 March 2007 21:29 Go to previous messageGo to previous message
Cuppa Joe is currently offline  Cuppa Joe
Thanks for the tips, guys! Lots of options to consider.
I've never built any boxes from scratch, but I've modified the baffles on home stereo speakers that I had found in 2nd hand stores, but only if the build was solid. In the past, I've had to borrow tools as needed, with limited degrees of success. One tool was called a keyhole saw (hand-held, unpowered), which was convenient for such work, but the cut was pretty rough. What can you guys recommend in place of a keyhole saw for baffle surgery on a pre-made speakerbox? (I usually leave the woofer cutouts alone and modify the mid/high sections.)
Previous Topic: Hand drill has a stuck chuck
Next Topic: Anyone using biscuits when building speakers?
Current Time: Fri Nov 06 22:46:11 CST 2026
