Home » Audio » Craftsmen » Newbee Tools
Re: Spend the money on precision [message #29896 is a reply to message #29895] Sat, 24 March 2007 16:27 Go to previous messageGo to previous message
Since you are not going to use as table saw, I recommend a PC 423 circular saw. It's a left hand saw which is better for precision cuts by a right hander. That's opposite the recommendation for rough framing.
At the low end of acceptable is the PC 690 router. I have one with both the plunge and fixed mounts. I use both to the point that I am going to buy another motor so I don't have to keep switching.
Bob
Previous Topic: Hand drill has a stuck chuck
Next Topic: Anyone using biscuits when building speakers?
Current Time: Fri Nov 06 22:46:39 CST 2026
