Home » Audio » Craftsmen » T-nuts, their care and feeding
| Re: T-nuts, their care and feeding [message #29883 is a reply to message #29882] |
Mon, 12 February 2007 12:58   |
Bob Brines
Messages: 186 Registered: May 2009 Location: Hot Springs Village, AR
Master |
I find that the best way to seat t-nuts is to get a hex head bolt of the right size, place a washer on the outside of the panel and thread the bolt through the t-nut. now tighten down the bolt with a socket wrench or an end wrench until the t-nut is seated. This also guarantees the the t-nut will be square with the hole. Bob
By: lon on Thu, 25 January 2007 12:40
By: lon on Fri, 26 January 2007 13:36
By: lon on Sat, 27 January 2007 10:53
By: gfederys on Fri, 02 February 2007 07:53
By: lon on Sat, 10 February 2007 16:05
By: lon on Sun, 11 February 2007 11:41
By: badman on Thu, 03 June 2010 16:22
By: badman on Thu, 03 June 2010 23:11
By: badman on Fri, 04 June 2010 09:40
Re: Just to muddy the waters....
Re: Good point
Current Time: Mon Nov 30 12:16:58 CST 2026
